Purchase Question
Titus
Na
Ca
I'm looking at this 85 cj8 and it looks very clean only a little rust on the window area. The only concern I might have is that is has been driven very little to none over the last 2-3 years. He has kept it in a well maintained barn, ran it "regularly" and even kept the insurance on it (I guess that means he had the intent to drive it). It will have to pass smog to be sold in CA so that is some type of buffer but is there anything I should be concerned about?
Thanks
Mine had sat in a carport for 8 years in California. I thought I had a gem with only 65k original miles and all original parts/paint that looked fantastic. Almost everything that had been sitting with liquid needed to be replaced. The brake booster rusted after pumping the breaks and completely failed while driving, the fuel gauge pickup tube rusted off (also while driving) and I had to drop the tank to clean it out and replace it. The oil was BLACK and took about 6 changes before it looked like oil again. Now that I've replaced a lot of components and converted to HEI/Fuel Injection it runs amazing but it cost me a couple thousand more than I originally expected.
3 years is definitely not 8 and since he actually ran his you might be ok.
dyldebus... is the Scrambler below yours? Saw this one in Solana Beach a few weeks ago:
You have to expect when buying an older vehicle like this that there will be an handful of things go wrong no matter how much you scrutinize before buying and no matter how honest the seller is (which is a rarity). If it was run through a bunch of water and the diff vents aren't set up right, you will probably be in trouble. Buy it and plan on spending some money on it.
