I made ramps out of a couple of 2x10s supported by cinder blocks and then walked it off on its pallet while my dad helped support the top from tipping with a rope. Would have been easier with an engine lift which I didn't have them. It weighs 660 lbs with most of that up top. Then when in the garage I walked it on the pallet to the back end. Used 80' of 8/3 wire. Didn't need the 3 wire but it could be used for a fuse panel someday.
Got my intercooler hooked up today. I took a small 1/2" hose from the pump outlet to an engine oil cooler that sits in front of the pulley/fan. From there it goes into a small canister I made from black pipe then into my main tank with another 1/2" hose. The oil cooler cools the air out of the pump and then condensation forms inside the canister there's a purge valve on the bottom to remove moisture before it gets to the tank. I also plumbed 30'of half inch black pipe to the front of my garage where my other water purge valve, regulator and dessicant dryer are. No wet air for me!
