quick question
scott anderson
Old age Mutant Ninjaneer
Paragould
ar
I got rid of my fuel tank...put in fuel cell..i had an intank pump..decided to go with inline pump...now the question..should the pump push gas thru the fuel filter like it did before..or pull..my guess is push to avoild possible cavitation..any thought
remember i run a 5.7l chevy efi from a 2000 yukon
The pump should be fed from a screen or a sock. The fuel filter will be on the pressure side. You are correct with not putting a filter on the pick-up side because it can cause a restiction for the pump especially when the pump and fuel is very hot.
FWIW, the inline pump that came with my ProJection 4Di kit actually uses a filter before and after the pump, in addition to the "sock" in the fuel tank.
Yes but that plastic filter that Holley supplies with their kit is more of a screen than a filter.
