Quick seat question.
ScramFam
Registered User
Nowhere
OH
I just got a call from Collins Brother's Jeep asking me where I want my back seat mounted -- In the original mounting holes? OR Back further? I guess the issue is rear-seat legroom when the bulkhead is installed. What do you think?
Mount it back further....I did and it does makes a world of diffrence for the adult back seat pasenger. I also do not have the bulk head in any longer. In addition to mounting it back further I mounted it 1 1/2 inches higher as well.
Vinny
Since I run without the bulk head, I mounted mine in the stock position but used 4x4 to raise it by 3-1/2". Makes a world of difference both for the view and leg room. While Collins won't raise it on 4x4s, it would be an easy change to make once you receive the jeep.
Thanks guys. I had them go ahead and mount it in the stock holes. Jim said that spot was reinforced too. I'll look at it when I get it home and probably drill some holes and move it back when I put in a a full cage this winter. Seems like having the seat in the forward position might give the rear seat passengers SOME protection in the meantime.
I mounted mine backwards when I had the bulk head in place. It made the back passangers a whole lot more happy to be able to spread thier legs out a bit. I like the idea of lifting the seat up more. Maybe some used body lifts or hocky pucks in place of a 4x4 would work well. Then you could gain just a little under seat storage for bikini top or small tool bag?
One of the nice things with the 4x4s is that it creates a pocket. So I just slid my first aid kit and small tool box under the seat and then put a bungee chord from seat support through the handle to the other support to hold them under the seat. Easy access but secured. Just remember that you can only put something under the seat equivalent to how much you raised it. Otherwise, when the passengers sit in the seat and start bouncing on the trails you hit it.
I ride in the back seat at least a few times every trip since I let my daughters drive. When my youngest (11) drives, I let her sister (13) ride shotgun (amazing how much her driving has improved just from this). Have ridden in the back for up to a 30 minute stretch in relative comfort.
Kohldad:
That sounds really cool. How about some pics?
Also, has anyone ever gotten pulled over for having passengers in a CJ-8?
Is there a legality issue there, or no?
As always, thanks.
I vote for lifting the seat too. In my CJ7 I kept the seat in the traditional place, but I just lifted the front only. I don't know if all of you lift both the front and rear, but I just lifted the front. It makes the seat have a more comfortable (recliner like) position which is less fatiguing. Helps with the legroom/leg position without sacrificing the space behind the seat. I just used a 2 x 4, not a 4 x 4.
It probably depends on how bored the police are in your area, probably along the same lines as the post about a month or so ago about the Scrambler owner who was getting pestered about running without doors.
If you have a seat and a seat belt for every passenger, it should be no problem, but if the local law decides to be a stickler about it, he may ask to see your title and/or registration which states the total number of passengers allowed. If it says 2 instead of 4, he may have a case against you. Wheren I get mine on the road, I plan on making sure I say "4 passengers" when the insurance company fills out the registration paperwork for me, and when I get a new title, just to cover my butt. That way I will have no issue if I run around with a rear bench seat in the future.
I had a friend a while back who had a Pontiac Firebird. A local cop with a grudge used to pull him over all the time for having 5 people in the car at once (3 in the back seat). He used to wait outside the highschool grounds for him, and as soon as school let out, he got pulled over. The tunnel for the drive shaft didn't allow for a traditonal bench seat with 3 seat belts, although I'm sure the middle passenger liked a ride home in a Firebird more than he liked walking home.
