Radiator HELP!
TXJEEP
Copper Canyon
TX
Similar to my fuel tank challenge, I am looking for a replacement radiator that is sure to fit my 1982 Scrambler. I cannot find the specific recommendations for aluminum, integrated or separate, transmission cooler, with proper fan shroud and EITHER electric or mechanical fan.
I am not swapping the engine. I just want to know what works stock.
Thanks.
Can you post a pic of your engine bay ? If you have the heavy duty cooling option or not I can point you in the right direction. If you can't post a pic , can you find out if your rad fill is centered or offset ?
If the fill is offset driver side, I've had good luck with radiator.com. I let them know what I had, and they sent me an exact replacement in a couple days. It was copper/brass, no trans cooler, and I don't run a fan shroud and haven't had any problems without one. Prior to that purchase, I bought an aluminum one with three rows off of eBay, with a center fill, and it was all sorts of wrong. Aside from having to figure out how to route the overflow, it was too big and my fan caught a big chunk of it when I started it up. Sent that one back and went with radiator.com.
Ha, great suggestion. I suppose I am looking for options. Thanks for playing.
It is already apart so the pic did not work out. The radiator cap is offset driver side. Does that mean it is heavy duty?
How many rows does it have? My 81 has three row and is the heavy duty, my cap is in the center. My neighbor has an 86 and has only two rows, center cap as well. If is an old copper one, a scrap metal deal might give you enough to buy an aluminum one. I would try get it plugged at a radiator shop, that what I did with mine. Good luck with your project
Oem rads were heavy duty offset, standard cooling were center fill. Heavy duty came with 6 blade clutch fan, overflow bottle , and shroud. Standard cooling had no bottle, finger decapitating standard 4 blade fan with no shroud. Overflow ran to a tube that points to the earth down by the frame.
I've seen aftermarket center fill rads with three rows so that's likely what you have.
Measure the distance between upper and lower tank. You need this measurement to spec a new rad. Also the amount of rows your tank has.
