Radio hot wire
Mistrornge
Shepherdstown
WV
What are folks using as their constant power for the radio? I know it’s not used for the original but I want a CD player.
With the CJ7 I ran a wire through the firewall directly to the battery. It was ugly but it worked.
There is also an illumination connection that I assume can be connected into one of the dash lamps. Is there a better method?
Thanks for your help guys.
Charles
There probably will be an unused constant hot in the fuse box. Just use a test light to find it
there is a single spot in the fuse on the fuse block that is marked clock that supplies constant power.
