Radio Wiring Question
Craner8
Orlando
FL
Dumb question: hooking up radio in 8. Have red wire and yellow wire from radio 'plug-in'. If I hook both together with the ACC wire from under the dash from the Painless harness, it works, but it will not keep presets. Have to reset each time I start the engine. One wire should work full time, but when I hook one or the other to the cigarette wire (full time) nothing works. Both red and yellow need to be hooked up together, but no presets. Ideas? Thanks in advance.
What kind of Radio is it? Digital? Factory?
Did you hook up the ground wire and the chassis ground strap?
If it were a factory style radio, I would expect a switched power wire and a wire for the lights inside the radio. If this is an aftermarket radio, it would be hard for me to guess how they expect it to be connected.
Joe
Aftermartket and cheap. Mounted in console. Yes ground no strap to actual radio. One one is probably for full time hot but that didnot seem to work.
Maybe a dumb answer, but I found hooking up a radio to be pretty straight forward, though I had to do it three times in a couple of months because they just don't make cassette players like they used to. I have mine hooked up as follows: red wire with a spade connector to the A/C plug, which is ignition only. Yellow wire with spade connector to the clock plug, wich is full time. Both of these are hooked up directly to the fuse box. Black wire grounded into the dash.
Sounds like maybe somethings up with your cig. wire? grounding, something else?
Had the same problem. Yellow needs to go to full time hot. Its the one that keeps the memory. Red to keyed hot. And you need a ground or the yellow will turn into the ground when you turn on the key which will wipe out the pre sets.
I put a switch in my yellow. So if I tow or leave the 8 sit for a long time I can cut off the battery drain.
I just did this in November. As stated above, I ran the yellow to the clock fuse spot in the fuse box. Works like a charm and keeps all presets (except when it fell out after I was messing with other wires down there).
you beat me to it!!...the yellow needs to go to the clock position on the fuse block...clock stays hot all the time..
And just for clarification - the only reason I run the ignition hot lead to the A/C is because the left side of my fusebox is junk. "Radio," in the bottom left corner, keeps blowing on me, but it is also ignition hot.
Sounds like something wrong with your cig lighter circuit. Radio should work with yellow and red hooked to power. I run mine that way as I find that having the "turn on" wire hooked to ignition is annoying on the trail. Otherwise you just hook it as described above for it to work like a normal car stereo.
Radio fixed! Thanks for all the information-- very simple when the yellow and red are connected properly.
If you connect the yellow and red together to constant power the radio will work but it will run your battery dead if the Jeep sits for a few days as the amp will be on all the time.
