- SoCal
- CA
Looking for opinions. Current drive train is AMC20/Dana 20 w/TF999 and Dana300. I'm on 31" tires right now. Right now it's tolerable, but highway RPM's are around 1900-2000 on the freeway. Ok on flat stretches, but not great especially when I start going up hills. I usually have to shift to 2nd on long uphill climbs.
I should probably re-gear to 3.54 or 3.73. I probably won't ever go larger than 31" or do any hard core off roading, just looking for something better for freeway driving and light off road. A re-gear would probably cost $2k+, since it would require a carrier swap on the AMC20 + parts and Labor, which is a lot for something that doesn't get driven that much. And I'd rather not dump that much money into an AMC20 so I've been looking at getting a Dana 44 rear which would probably cost just as much to setup, but at least it feels better than dumping money into the AMC.
The other option is I found a set of AMC20's and Dana30's with 3.31 gears for <$1000. I figure another few hundred to swap out bearing and seals and I'd have slightly better gearing that what I have now, but I'm not sure if it's worth the cost to do that just to be slightly better on the highway. Would it be worth the money to go from the 2.73 to 3.31? Or should I wait and just invest in the proper gearing? How would this affect highway mileage?
