Really OT-- Refridgerator
Stouttrout
Registered Jeep Nut
Sour Lake
Tx
Okay, this is really off topic but seems like I get mostly good advice on here so I thought I would give it shot. I picked up a fridge today, for the shop. It is an old one but still works. It is a Side by side and the freezer side is Ice cold, the fridge side is just cool. This is jusT a beer and soda fridge. I was wandering, Is there anything in that wall between the two? i wander if i can just cut a hole to let the cold air in? Anyone know?
went through this with the one in the house here.
The fan behind the false wall in the freezer side blows the cold air into the refridge side.
Check the cold/colder switch for proper moving of the damper that regulates air flow.I found a piece of styro foam partially blocking the passage way in ours.
I checked all that. Is that truly just a false wall? I am so tempted to drill a 4" hole in it with a hole saw. part of the problem is it is working doubletime in this heat but if the drinks are just cool it really isn't serving a purpose. The freezer side is never used and it is almost too cold. fan is working good and flap is wide open to the fridge side.
Probably hollow/insulation only... but...
I'd guess there is nothing in that 'wall' other than maybe some insulation.. but I'd hate to be wrong and there's a freon line in there.
Can you just take a 'hot knife' or something similiar and cut through the plastic... to see what's behind there? Or, crack the plastic (probably somewhat brittle) and break pieces off to make your hole?
Hate to see you get the hole saw or Sawzall out and goon up your 'new-to-you' garage cooler....
