Cutting out the old one next week, and installing the Classic reproduction. My ‘81 has L brackets poorly welded inside the frame rails. Does anyone know if this is factory? Most welds look like crap, so hard to tell.
Both my 8s had those L brackets inside and outside the frame and like you i thought they were home made but i inquired on this forum and found that they are indeed factory.
Mine were bolted on with long bolts and sleeves in those holes, pretty sure they weren't welded.
The rear crossmember had a very thin factory weld top and bottom if i remember correctly so those L brackets would be much needed reinforcement i would think.
