Scary ride
Oscar P
Central Texas
tx
I drove the Scrambler for its first decent trip this morning (40min at highway speeds) since buying it. Hands down the scariest ride I have ever taken in a Jeep. I refused to go over 60 mph in it, but mostly because it developed a vibration that sounded like the driveshaft was out of balance or something below 60, no noises or vibration. The steering.... oh the steering.... slightest touch of the wheel and she would jerk to the other side of the lane and the body would sway like it was about to fall over. I've driven my rockcrawlers numerous times on the road, and though scary, couldn't hold a candle to this experience. I'm going to try dropping the tire pressure down, see if that helps the touchiness. And I guess start investigating the vibration. Could easily be the driveshaft I suppose. Wow, I'm still shaking.
And forget about 5th gear, wasn't getting there. No way, no how.
"86 CJ8, 35x12.5x15 BFG All terrains, RE lift (maybe 6in, it clears the tires fine), 6cyl, 5 speed, half cab
Any lift on the jeep. Check front end for worn, loose parts. I had a 3.5" lift and got a vibration at around 55 mph when I took my foot of the gas. Ended up needing a double cv joint
Often the culprit is extended shackles. People put them on for a cheap lift, but it changes your caster angle. When I first bought my scrambler, it had 5 3/4" shackles. I looked like a drunk going down the road. They should be 3".
