Scrambler toy hauler?
  • Thread starter Thread starter Curley
  • Start date Start date
C
Curley
Guest
Who makes a good fifth wheel Toy Hauler that will hold a Scrambler? I have been looking at the Raptor, 3318ss by Keystone. It has flip-down beds that might not allow the width for the CJ-8. Surely there are others that will work. Ideas?
I'm interested too as I've been looking for a while. Only found one and it was way too heavy for my SRW. I'm considering going either small slide-in camper with a trailer, or just a standard cargo trailer with extra 18" in heigth then customizing what I want.
Of course, one of my biggest problems is the required 84" door height opening which is about 12" higher than most toy haulers. If I had a TJ/YJ on 2.5" lift and 33s, wouldn't be near as much problem, nor the fun.
Hopefully someone else can point us both in the right direction.
Just get a set of those Save-A-Space spares and run those on the axels when you load up then change to the good tires and wheels when you off load.
All you need is a High lift and one of those Milwalke 24v Impacts. Make quick work of a tire change. Then you shouls be able to go with about any race trailer.
BTW, when you are looking at the trailers. Look for one with the 16" heavy duty tires. They just pull so much better. We just got a new race trailer last year, but I forgot the brand. It is aluminum floor and walls, and extra wide. Really nice. I will try to find out next time I call the shop.
Carl
Call me lazy, but wheelin is enough trouble and heart ache that I don't need to do four tire changes just to go wheeling. As far as cargo or race car trailer, for a couple hundred dollars, when ordering you can have an extra 18" added which takes the standard door to a 7'+ door. The problem is this can't be done with most toy haulers.
Most of the toy haulers I looked at were for ATV's. They arn't heavy enough for a Jeep and the axels are to far forward so if it does fit in the weight is to far back. I know a guy who had this problem he had to add a third axel. You can buy a car trailer converted to camping Very Expensive. Build YOur oun.
a friend of mine took a school bus and chopped it in such a way that the rear was a car hauler and the front was a camper...wish i had a picture..it is really hard to explain what he did...but it was nice. His truck was a show truck on 44's...the rig had the "drive over " fenders...a little off topic..but it worked well for him
