SE 8274 and cooling
wm69
Silver Member
God's Country
AR
FINALLY got my SE 8274 mounted this morning. I got the soft vinyl cover to go over it and with the cover on the darn radiator opening is almost completely blocked. Anyone else run a cover on their 8274 and if so does it affect cooling?
I've seen quite a few of the 8274's on a CJ so I know a Jeep will run ok with one mounted, just wondering if the cover will cut out even more airflow......
When I bought my 86 CJ-7 in 91, it came with an 8274 on the front with a soft cover as well. I noticed above normal engine temps and saw how much of the grill was blocked. Upon removal of the 110 lb winch, not only did my engine temp go down, but the front of my Jeep went up a few inches as well. Now this was with the original two core radiator and I later got a 3 core that dropped the temp more; so much more that it would have been fine with the winch on it......so make sure you have a good radiator and such.
I ran a 8274 with cover on my 82 CJ7 with AMC 360 for over 20 years without any cooling problems and now have it on front of my commando with the same CJ front clip and motor with no problems.
Well first thing I have to do is get the winch working! I bought a motor, solenoid pack, solenoid cover, and remote and plug for it, along with new battery cables. Got it all mounted yesterday and didn't even get a click. Got to take the solenoid cover off and get a voltmeter out and see what the problem is.
I've got a newer 3 core rad on it so hopefully it will be ok. If not I'll pull the cover off and do without it. Looks like quite a bit of air can get through the winch as long as the cover's not on it.
Thanks for the replies!
My 83 runs as cool as it did without the 8274 mounted up--fear not . . .
That Commando is awesome! Is that the model with the square front clip originally? Oh, and my covered 8274 hasn't given me an issue with the 258 or sbc, and it typically runs in the 100-115 range here.
