Side Steps
Gueon
Thatcher
AZ
When did Jeep start offering side steps and on what packages were they available. For example, would it have been an option on our '81 SR?
Second question, how are they installed? Are there pre-drilled holes in the body/frame/tub or is this something that you have to measure 5 times and drill once?!
Do they install through the floorboard of the Jeep, are the heads to the bolts visible without carpet?
Thanks.
I had a set on my base model '81. They attached through some factory holes just outside of the outer seat bolts in the tub, and yes they'd be visible without carpet.
81 were a diamond tread pattern. 82 was black and smooth. 83.3 and up were smooth and body color. Generally speaking that is. :cheers:
Ok, time to start looking for diamond tread....
