SLow Mo Update
The Real CJ8
Small wheel
fredricton
NB
Well I finally got the MC2100 installed and running and all I can say is WOW
Easy to rebuild, set the mixture at 2.5 turns and that was it....Carb is the 1.08 version from a 84 E300 ford van with #48 jets
AND
I took it for my first ride on my property and for a quick boot down to the gas station as the gas that was in there I think has been in there for many years....
Let me say I was floored with the power....
Someone has rebuilt the engine as the OD reads about 260000km but I could not belive how much jam it had!!! First time driving a 4.2 and I have not drove it very much yet to compare to my 4.0 experances but I would say it was quite close though, Also i don't usually drive a standard so maby that was all it was.....
Runs a little weak until it warms up but I don't have the choke running yet and will probably just go to a manual choke.
I need to sell the trailer to fuel my jeep addiction next up is I guess (GROAN) bodywork which I would like to do a nice job of but I dont have a lot of patiantce for such things...
Still looking for a half hard top but my wife seems to think i can fluke out finding one which I am doubtfull of but still hoping for.
Joel
Nice, :thumbsup: I agree with the choice for a half top, they're the best choice e for Scramblers.
List of things i need to do or replace (That I know of)
1: Front bumper has small bend as most I see do.
2: Leaf springs have about 1 1/4 movement before they bottom on the axle snubbers. So am thinking 3 or 4.5 inch lift with I guess 33x10.5 bfg's i like the tall narrow tire look but not the best for wheeling in my experiance.
3: Floor pans are rusting beside the rocker panels (GROAN) not to shur what to do there I guess floor pans and rocker panels are in order to make it right.
4: I would like tilt steering so need to find what works.
5: I imagine I will need to do all the breaks they work but it is nice to be safe and have peace of mind.
6: A little bit of rot around the roll bar mounts needs fixing.
7: Windsheild has a few rock chips.
8: Still waiting for my seat covers to get back to me after apolstry.
9: Tack does not work.
10: Temp guage does not work.
11: Might order a NOS crome bump for the rear from colins bros, But im not to shure if it will be to much crome.
12:I'll Probably take the tub of and try to presurve the frame some way as it is fully solid right now and do not want it to rust ....I know its alot of work but probably will be beter for the long run.
13: Passenger fender has slight bend in front maby i will practice my body work on that first.
14: Change oil might be a good idea
15: 4WD shifting is a little tricky so might need to check whats up with that,
maby switch to home made twinsticks while im at it.
16: Would love to OX the front and back and thats it for axle mods. (DREAM)
17: Probably should figure out what i have for axle gears.
18: Engine tune up.
19: FIND half hard top near by.
20: Try to imitate a factroy paint job.
HMMM That list does not sound to bad but i bet it will still take me 2years to do
joel:D
