ebertf
Active member
- Soldotna
- AK
Mainly collecting Parts currently.
I have a frame from a Postal. A body from a different postal top included. Axles I am removing from my postal. A Cummins 4BT,
5.9 heater grid, 5.9 damper, HX30 Turbo, 350 hrs. run time, Ford 6.0 starter, power steering pump and vacuum pump,+80 Hp 6 port inspectors, custom modified an A-pump with over the road governor 2700 gov spring, chevy alternator, custom motor mounts, custom cross member custom-built Dodge/Chevy torque converter, and a built TH350 trans Out of a CJ7.
Pictures of the parts attached. The postal body is bent in front thinking about cutting the front firewall and cowl off and welding on a left hand drive CJ7 cowl and firewall.
