STC Full top frustration
kohldad said:
Notice that the front bar doesn't fold down very well for storage. For this reason, I usually leave it up with a small bungie to keep the upper door frame bars snug to the window.
I've got the STC half top which essentially the front bar system alone. I was dissapointed in their failure to address dropping the top. I was thinking about replacing the front bar base bolts with clevis pins so I could take that whole abortion off and throw it under the toneau. That was last fall, but winter in NJ came quick and it was time for the hard half top.
Last time I put the top on I did change out all the bolts for 1/4" x 2" pins secured with hairpins. Was a lot easier to remove the top, no additional rattles when the top was on. The pins are definitely the way to go.
Finally got my full top. Gotta say, I'm diggin' it. But it took some getting used to. They've got some things really figured out, and some they don't. The fit could be better. Mine's adjusted all the way and still a lot looser than the Supertop I bought for my CJ7 a couple weeks prior. And what's the deal with so many pieces on the side window rails to tuck under? It'd be sooooo much more user friendly with a single piece. Back window zips out wierd and is a cheesy set up how it tucks under (no plastic, just doubled over fabric or so it looks). They could work on their customer service a bit too. Dude was a bit of a jerk when I called to check on my order. The zip out windows are AWESOME and almost cancel out the poor doors (they just don't fit as good as the Supertop ones I'm accustomed to). I've gotten waaaaaaaay more comments on the '8 when I've got the windows zipped out with half doors on, than ever with the half cab soft top. I put two rear jeep seats in the back and the kids labsolutely love it. Seating for 6. Kinda worried about how it'll hold up on a long trip. Overall, on a scale of 1 to 10, I think it's about a strong 7........but that's just my opinion.
Sorry about that. I did a complete web page redesign making it easier to add additional data plus find things. Anything that wasn't an actual page was pulled from the site to make room.
I'm trying to find the pictures now. If I can find them, I'll repost them and provide an update here.
Edit: Found the pics and have the pics back. Took some digging, but backups save the day again.
Thanks that looks pretty good thats the only top the Scrabler I'm buying doesnt come with.
davekern said:
When did you get the top? I have the STC and like it (not love, but seriously like). But, it is different. Mine is black and looks like the one at http://www.kaylinetops.com/images/CJ8_FASTlg.jpg
The windows don't come out but roll up. So, on the trail the whole side and back roll up and it is like a giant bikini top. The only thing that I don't like is that the sides can be tough to get back into the slots if it is not hot and in the sun. I thought I didn't like the windows not unzipping, but now maybe not.
When I take off the top I also take the bows off. I leave the L bracket on the back. You can see pictures at
https://www.cj-8.com/forum/showthread.php?t=12429
Works good so far. I only use the top for trips. It does not flap at all. I store it in the rafters in a garage along with the bows. I have put it on, taken it off about 8 times with no problems, and it takes about 1 1/2 hours each way. I just fold it for storage and things are fine.
Dave
I've got the same top, also in Southern California. I love it. It has straps on the back, too, that seem to allow it to be tightened to keep the sag out.
I have the STC top too, and like it. My windows are the roll up type and rolling them up takes a couple minutes and it's like having a full bikini. I also have the half bikini and a cover for the bed as well. It takes some time to get everything just right but thats just part of owning a jeep with a soft top.
I don't mind the looks of the bars, and it gets tons of compliments when I roll the windows up.
I noticed you had alot of slack in yours and was wondering if you have adjustable nylon straps? Mine came with adjustable slider/fabric straps to take all the slack out of it. I can make it as tight as a rubber band and it looks great, only problem is though you have to have it out in the sun to make it easier to work with, but I am not putting the top down when it's cloudy and rainy anyway so that point is kinda moot.
I have mine adjusted pretty tight, no flapping or wind noise at highway speeds, it's actually quite comfy and relatively quiet for a soft top.
Scramblers are so long that having a soft top makes it harder to deal with, there is so much more to it and no way around it really. Probably will just take some getting used to. Larry.
You can see pics of mine in the for sale section under 82 scrambler for sale in Cincinnati. You can see how snug and wrinkle free the top is. I would think yours should be the same way. Larry.
Unfortunately, they made a couple changes I didn't expect. One, when you get the zip out windows, there isn't a means to roll them up. I had an old top that I used once and loved it because when the rains came on the trail, you popped a couple of snaps and you were done.
Other issue is there aren't any straps in the back to pull the top tight. They rely on the rear corner sections to pull the top tight. Right now the rear bar is at it's fartherest. I'm hoping that the top shrinks over time and makes for a tighter fit down the road.
Ah ha,,,,so they made some changes. I agree, I like the roll up and snap it windows, that way they are always there when you need them. Zipping them out leaves you with having to put them somewhere, usually in the way.
Kind of the same deal with my wifes corvette, taking the t-tops out is a pain, you have to put them somewhere and worry about them getting scratched in the process, that was the worst invention ever.
Something else I noticed in the pics with those zip out windows the top just doesn't look as clean with all that overhanging material around the top, guess you need that to keep the weather out though.
I am surprised they don't have the straps to pull the top tight anymore,,,seems that would be necessary but I guess they thought otherwise. Stick with it though, it's better than having to remove a full hardtop everytime you want some open air, those things have to be freakin heavy to deal with,,,lol Larry.
We may not have to worry about the STC tops any longer. Tried to order one last night and recieved the following...
The comments for your order are
I am sorry but we are going to have to cancel your order for the STC Scrambler top at this time. We have been notified by the factory that they are not accepting any new orders. They are about 8-12 weeks behind in orders now and the future of Specialty Top Co is uncertain.
Please check back with us in a few weeks to see if there is any status change. Right now the only thing we have to offer is the Bestop line of tops.... Sorry.
Anyone have a Bestop? I may just have to have a fastback top made.
Ha - wow. I was about to put in an order. I've never seen any pics of the Bestop model or heard any reviews. Any info?
NOT TRUE. I am not sure who you placed your order with JL but I just placed one with STC. I have place 4 orders with them in the past and have never had any problems. He is a real talk to guy and when I asked him about it he said that he is still making tops and will for anyone that wants to place an order. They are about 8 weeks out. It does not sound like he is stocking them but the last top I ordered he said the same and it arrived in about 4 weeks. I just ordered a ZIP out today.
Dan
You can call STC at 866-487-9944 or 303-487-9939. JL, I ran into something like this once before when a company didn;t carry the product I was looking for and wanted to switch me to another brand. Not sure if that is the case or not.
Who did you place an order with.
Unfortunetly, I contacted STC directly and recieved the following response:
-----Original Message-----
From: Specialty Top Sales [mailto:special1174@earthlink.net]
Sent: Tuesday, October 03, 2006 2:41 PM
To:
Subject: Re: Are you really not accepting orders any longer?
We are trying to sell the company so we are not accepting orders, at
present.
Blake
Anyone have a Bestop? Are they snap or trackloc type?
Sounds like someone at the factory was wrong then. Maybe the right hand not sure of what the left is up too. I talked to the owner and have my top on order and he assured me he is still taking orders. That was this morning. I do not like the Bestop. Not enough Bows in my opinion. I have only seen one in person and it was really saggy.
That's what I've thought too. I'll get ahold of them and place my order. I'm willing to wait. I wonder if I can get them to make me one with black sail cloth... Anyway, thanks for the info. I'll update when I place my order!
Joe
