STC half top frame - what to do?
CJeep
Scrambled
Easton
CT
I was smart, or more accurately, lucky that when I bought my Scrambler about 2 years ago, I bought an STC 1/2 top.
Just installed it a few weeks ago, and, overall, I like it. But what I did not realize is that there is no practical way to fold down the frame once you take the top off. I found two reasons: 1) with the aluminum plates that attach to the top of the bulkhead, the main bow will not sit down low enough to contact the rollbar, so it's up kind of high (as apposed to the bow laying plat on the top edge of the bed). I could live with that but 2), the rods that go to the windshield and create the top of the doorframe, they stick out into the now open doorway so much, they are really in the way and would be likely to impale my elbow every time I turned the wheel. It's hard to describe, but they stick out into the door opeing about 1/2 way to the dash about chest high as you sit. It's no good.
As I recall on my old 88 YJ, the rod that served this function was foldable with a little locking collar to lock it straight when up, and you could fold it down so it stayed out of the way when the rest of the top was folded down.
For now, I have the frame up and a bungee running from the main hoop to the windshield, so it does not fall backwards.
What do you guys do? I could make some mods, but maybe I'm missing something? I don't want to have to remove the frame every time, that kind of defeats the purpose of the soft top for me.
BTW, I will post pics once I need to put the top back on. Overall, it's nice, but it's clear to me that Bestop make a better product overall. Hopefully, they will buy the rights to this top and repalce the electrical conduit that makes up the main hoop and re-think some of the other aspects so it folds down better.
quick disconnects
Had the same problem....
What I ended up doing was place quick disconnect pins on the hoop brackets.
I take it off, separate the halves and put them between the seats and the bulkhead.....then you're done with it.
Tried monkeying around with the hoop but there was nothing I liked, having to unbolt each time was tedious so I grabbed some quick disconnect pins from a hardware store and that does the trick
Sounds like a good plan, I may give it a try.
BTW, I live metrowest and work in Boston, so I'm not far from you at all. Wouldn't mind meeting up with another Scrambler driver/mechanic/vodoo priest/masochist.
Yeah sure thing, there's another on the board that I've been trying to meet up with for a while. My scrambler is down as I'm doing a 360 swap but shoot me a PM and lets see what we can do
I did the same thing, replacing the bolts connecting the frame to the brackets with cotter pinned....uhhhhhh.....pins.
Yeah, I have to remove the frame, but if I take off the top and leave the frame, it looks a little "Sanford & Son" to me. Removing the frame takes about the same amount of time as removing the top does, so it's a 15 minute ordeal.
I thought that it would be nice if somebody designed a frame to function like my old CJ-7 did. It extended out to clear the downtubes of the rollbar. Oh well.
