Steering Column/Ignition Cylinder Removal
JimB
Anna
Tx
Hey Guys,
I am trying to get the Ignition Cylinder out in my 84 Scrambler. I read in my Chiltons to turn two clicks clockwise past the off position. I've done that but I still cant find where they are talking about to use a small screwdriver to stick in the column somewhere and release it.
Need some direction please.
Thanks
Jim :confused:
Try this mate.
I did mine. I Had to break the platic seal in the square hole which allowed me to get to the the cylinder. There is some kind of retainer clip on the ignition cylyinder once I pushed a screw driver into the plastice hole it pushed in the spring and I could pull the cylinder right out.
Wayne.
There are 2 square holes in the picture. One at 12 o'clock and one below and to the the right. The lower one on mine has a plastic piece in it with a couple of copper contacts. Thought I read somewhere that it was the key buzzer if you left the keys in?
Do I need to remove that? Is that the square hole you're talking about?
