Steering Wheel Rebuild Question
argon2112
New member
New Fairfield
Ct
I am rebuilding my steering column after I had a small fire that burned up the signal wiring & internals. I bought another column and cleaned it up but I am having a hard time making the steering shaft fit the length of the column. The steel column does telescope and I have it fully extended but it won't make the length. I've tried multiple approaches to making the length work but it's too short for some reason. Is there a trick or something I'm missing? Any insight would be helpful. I have a manual and took notes so I cannot figure out what is wrong.
Measure the length of your original and the replacement. Some of them can have a difference ot around 2 inches. I'm guessing you have the bolts put in behind the dash so you have it bolted in. If short, may be time for a new aftermarket steering shaft. Make your shaft is extended. They come with plastic pins that when drilled or melted out allow additional length and collapse on impact.
I had this trouble as well. I. I found that clamping a vice grip to the shaft with just enough force that I could tap on it with a hammer allowed me to lengthen the shaft about 1.5" or so. Once I got it moving it moved pretty well.
Thank you. Yes it worked and now it's back to 33 inches.
