No. I've run 33's on 8" wheels for 16 years, and I've never had a problem. I like the fact that it keeps the tires inside my wheelwells, rather than getting the rollerskate look. On the other side, the sidewall is a bit more vulnerable on the 8". Depends on your preferences.
I think it is the other way around...with a narrower wheel, you are less likely to lose the bead when you air down (but as mentioned above, the sidewall is more vulnerable to abuse).
