Tachometer question
RubberDuck
Baltimore
MD
Slightly off topic as it pertains to a CJ-7, but I'm in the process of combining 2 CJ-7s into one. The better of the two, a 79, has a great body/frame/engine but a totally roached interior and cut up dash, etc. I'm taking the whole interior, dash, etc out of a 84 Laredo.
The laredo has a factory tach/clock installed. I know I can just hook the clock to a hot and be done with it, but is there a way to retrofit the harness in the 79 to accept the tach? I thought about pulling the harness out of the 84, but that had all the of the ECM equipment on it and would probably be more of a nightmare to retrofit.
I had been told that all the harnesses were the same. Like reguardless of whether yours came with a tach it or not had the wires there for it. This may or may not be true, just what a friend was telling me.
This helped me the other day:
https://www.cj-8.com/forum/showthread.php?t=26530&highlight=tach+hook
Tach: unplug 2 red wires shown in above picture, then plug 2 red from tack into those, black is ground.
I think some of the tachs can be 4 cyl or 6 cyl be sure have correct setting.
Orange wires from the tach plugs into the orange wire on the clock, the clock orange wire plugs into marked spot at fuse panel.
Didn't think that tachs were offered before 81 so didn't think the wiring would be there.
Yeah, they were available way back in the day. Buddy had a '77 with factory tach and clock....... Wiring should be there.
