TF(Torque Flight)727???
A
AZScrambler
Guest
I just found my 401 and would like to put on the Torque Flight 727 along with the Dana 300 transfer case. Is there an adapter? I have looked into it a little and have checked Advance Adapters catalog but did not see one. Also is there another alternative and still stick w/AMC? I heard there is another transfer case that would bolt up.
C
CJATE
Guest
I have seen this combination done once in a J truck. There isn't any need for an adapter because it all bolts together. I also believe this is a great combination as far as strength. There might be some issues with front driveshaft clearance and the 727 pan. I have heard many CJ owner say you need to lift the CJ 4" over stock to clear the Tranny pan. You may want to investigate clocking the transfer case instead.
W
wiltech
Guest
Wouldn't you have to clock the transfer case downwards to improve the clearance. This would reduce you're ground clearance even more.
Tony W
