The rollbars
WillyT
Scramblered
chicagoish
IL
What's the outer diameter of the rollbar? I'm going to be dolly-towing (soon to be) my '8 home and I need to have working brake lights, etc. So I figure I might just pick up some cheap trailer lights, mount them on a board, and hang the board from the rollbar (it has a half-cab on it right now).
Does that makes sense? Or is there a better way to do it.
Also, from what I understand, I should disco the rear driveshaft. Necessary if I have the trans and t-case in neutral?
when I picked up mine I just rented a full-size trailer. No worries about signal lamps, no worries about driveshafts. Did have to borrow a buddies F-150, though.
can you put a battery in the Scrambler and get your flashers to work? I would be very tempted to rent or borrow a trailer (u-haul, etc)...Scramblers weigh less than 4000 lbs.
Like the other guys said, try to get a trailer. If you're going to dolly it, definetely discon the rear driveshaft. If you do that then you do not need to put the tranny or trancase in neutral.
X4 on the trailer.......I rented a uhaul trailer for I believe was $60 a day at the time. The scrambler had 33" tires and was told that their front wheel straps would not work. I used my own half of 2 cargo straps with the ratchet and it was long enough to secure the front tire with their strap. Then put a couple of straps on the rear. The surge brakes worked real well. Just a quick tap on the brakes and you could feel the trailer slow the truck down.
I keep trying to get to u-hauls website, but something's broken there :banghead:
I'm not sure why I was so set on the dolly idea :shrug: I'll have to triple check on the towing capacity of my Trailblazer.
When you go to rent the trailer they will enter your vehicle and the one that you are wanting to trailer for compatibility.
Yeah, I checked that already, for the dolly. I didn't check for the full trailer, though. Once it's back up, I can find out.
If I was smart, I'd rent a truck to go with the trailer :D
