TJ hood rod pic request-
mysunnshine
Phoenix
Could somebody with a TJ take a pic of how the end of the hood rod orients as it goes into the locating hole in the grill for me please? I had to modify one and did not verify orientation before I made the cut...... :banghead:
Does the part that goes into the grill face forward? Thanks for the picture BTW. :)
Sent from my SM-G920V
Sorry, should have backed out further.
The front of the Jeep is at the bottom of pic, the top of pic is the engine compartment.
So if you turn your piece 180* it would be the same as mine.
The end of the rod points to the engine and the little bend sets flat on the top of the grille, as the upper pivot is at a slight angle to the slot.
Reread that..... confusing :banghead:
180* from what you posted is correct.
