Towing with my Scrambler
Going Postal
Corvallis
What do you guys think about this trailer I have found. I'm looking for a small car trailer to tow my Amphicar behind the Scrambler.
It's made specificly for the Amphicar and seems to me like it would tow well. It has an approximate weight of 800 lbs, 3,500 lb. gross weight, so the useable capacity is approximately 2,700 lb. The Amphicar weighs approximately 2,300 lbs. So I'd have roughly 3200lbs behind me. Is that doable?
Factory tow rating is 2000 lbs... I'm currently running 4:11's with the 33" tires but have been thinking about taking the Scrambler back to stock height and maybe 31" tires. I have an 89 YJ that I'd like to build up for off road and keep the Scrambler for the street and looking mostly stock. With the lower gears and 31" tires it might work out... Maybe??? It would need brake work for sure. I also have a 4.6 stroker ready that will defiantly help the towing ability. Or am I being overly optimistic?
Biggest issue with towing is length of the trailer and width of the tow vehicle.
Both are against you in a Jeep. Good thing is that the scrambler is longer than most jeeps. The farther out you can get the tires in width the better. Also a lower Center of gravity will help but more at high speeds.
It probably would have been better to have dual axels on the trailer. That way your tounge weight would not be affected as much. Plan on keeping at least a 10% weight on the tounge. Other wise a sudden stop or something will tend to lift the rear and lessen your braking.
Also brakes on the trailer axel and a controller in the jeep will help. Always nice to have help in getting the trailer under control. Espically on a long downhill.
Looks like it already has surge brakes. They are OK, but eletric is better. Just rember that you have a load on the back and plan your moves much farther in advance. You should be OK. It just requires more time and experience.
If you get into a situation where the trailer starts to wag the dog. Just rember to take the foot off the gas and slow down naturally. NEVER, NEVER touch the brakes in that situation. It will swap ends and you will be in a world of hurt. Also try to stay out of steep hills with that load and you should be ok.
You might want to look into an auxilery airbag for the rear suspension. Or going to a add a leaf to handle the extrra rear load and help level out the jeep when you add in the extra weight.
Well, these are just a few things I have learned towing junk. Mostly go slower and be careful.
Carl
After my accident last year, I am extremely cautious about towing. I would probably be okay using a Scrambler and a good deal of care to tow that trailer for a short trip around town at low speeds, but long distances or highway speeds would be out of the question for me. There is just too much that can go wrong. And if something does wrong and it is discovered that you are exceeding the capacities of your vehicle, you can be exposing yourself to quite a bit of liability.
CBRogers said:
...Also try to stay out of steep hills with that load and you should be ok...
Stay off steep hills? In Alaska?
Just how does one go about doing that? :p :D
