Trailer Info needed
CHIEFWAHO
Former SOA VP
SOA Board Member
Thayer
KS
Anyone experienced with pulling a 36 FOOT (receiver hitch) 2 CAR HAULER TRAILER???? I have been kicking around the idea of getting a trailer that will haul 2 Scramblers. Had been looking at goosenecks until I saw this trailer on Ebay.
http://cgi.ebay.com/ebaymotors/ws/e...&item=4531118328&rd=1&sspagename=STRK:MEWA:IT
A trailer like that would allow me to keep my fiberglass bed lid on and I wouldn’t loose my covered storage area in the bed. Any suggestions, ideas or experience on this matter would be greatly appreciated. Just not sure how a trailer like that would pull?
Or if anyone has a 2 Scrambler trailer for sale within reasonable driving distance send me a PM.
Just my .02 worth. That is only a two axel trailer. You will have a lot of tounge weight. As far back as those axels are think about 4000lbs tounge weight. Thats a lot for any pickup. You could have the tail wagging the dog. I wouldn't even consider it withoud three axels or a 2 ton truck to pull it.
x2 - can't imagine you would want that much on a bumper pull anyway...but who knows.
I used to operate a car hauler, 1 ton chev with duramax and a three axle 53 foot wedge trailer, (three suburbans on top). Currently we haul 31 foot travel trailer with Suburban with WEIGHT DISTRIBUTION HITCH. (very important)
You will do much better with a goose neck hitch, unless you have to tow with Suburban. That two axle trailer can be used with heavy duty pick up truck, if you load it with Scramblers nose to nose.
Almost forgot, also check weight rating of axles on the trailer.
Otto
My former life...
I used to own a small trucking company. I specialized in hauling boats. I had a double decker 36' bumper pull I pulled behind a Ford F-450. It pulled great with 12 boats on it. The tongue weight made it a ***** to get hooked up to as there was no moving it around if you were off an inch or so. But other than that it wasn't an issue. I had vac/hyd brakes/axles put on it because the electrics didn't stop good enough for me. I also had a hitch on back of the trailer so I could stack all the boat trailers on one and pull the stack behind everything else....I don't recommend that to anyone though, it has a very high pucker factor.... :(
One major problem I see with it is the GVWR is 14K but it only has a 12,500 weighted coupler. This thereby reduces the allowable weight to 12,500 or 8,500 of cargo weight.
Would be aweful long and hard on coners. The safety and stability of a goose neck (preferably fifth wheel) would be well worth loosing the truck bed space.
I used a 16' bumper pull when I first got the truck and then switched over to a 23+5 fifth wheel flatbed after getting a hitch installed. Even though the 5ver weighs an 3,000 lbs more than the bumper pull, the difference in stability is amazing. Will probably be upgrading the 23+5' next year to a 26+5' without ramps so I can haul two jeeps.
