Transmission mounts Looking for replacements.
HWB3
St. Louis
Mo
Have a T4 and the rubber on the mounts between the transmission and the skid plate are completelt deterioated. Cannot seem to locate replacements. Any help?:confused:
Thanks man. Always forget about the obvious choice first when dealing with parts. I guess a 28 year old vehicle throws me off or maybe I'm just getting old.
Anybody know what this thing is to the right of the tranny mount? Is is anti-torque bushing or vibration damper ?ImageUploadedByTapatalk1364944495.467197.jpg
Sent from my iPad
Thank you for the guidance. You were on the money with Morris 4x4 website. If I just would have scrolled down from the transmission mount picture I would have seen it.
While waiting for the the new poly bushings I temporarily used a couple shock mount bushings. Seems to be working.
Fixing this piece seems to have solved my transmission problems too.
Thanks again.
Sent from my iPad
Thanks again.
Sent from my iPad
I would guess since you mention a couple of bushings you know that it takes two stabilizer bushings. It looks like you are missing the top one in your picture, but does appear to be the correct stud. Here is a picture just in case.
Yes 2 bushings. The top one was completely gone. In comparison to your picture though I needed to stack both between the skid plate and the bracket arm. Maybe because my skid plate is dropped down with the lift kit?
Sent from my iPad
Did you order a new transmission mount? If you did it may be shorter and that would line up the stabilizer bushings. In your picture it looks like it maybe taller than what I had and the poly one I replaced mine with. Not sure if there is a difference between the 4cyl and 6cyl. Mine is a t5, but I think they are pysically the same housing. I can get a measurement on the height this evening if you need one. Another thing to check is the motor mounts and stabilizer stud.
http://www.jeep4x4center.com/transmission-mounting-stabilizer-stud-5358879.html
I had the same issue with the Jeepster transmission/tranfer case mounts and after buying a couple had to find one that was shorter and modify it. On the Scrambler it was not perfect, but close enough that it worked.
