transmission swap options
rstephenson
new braunfels
tx
Have another one of my brainiac questions.
Have an '83 cj8. 4.2 straight 6. 4 speed manual.
Is it possible to switch to an automatic transmission ? Are there other models and years that would be compatible ?
Would like to make it more user (wife) friendly, but i am not too sure where to start. Any help would be great.
THANKS in advance :D
For a not OD automatic do some searching on "automatic transmissions", "TF999", and "automatic swap" and you will find plenty of information. Some CJ's came from the factory with a TF999 automatic so parts and transmissions are available and the TF999 was also used in YJ's and some TJ's (I think). TF727 are also a bolt-in but are setup for driver's side front axles, can be made to work if you have enough lift.
Lot's of OD options too but they are more complicated and may require adapters ($$$). There are tons of threads on this subject.
Best quick bang for the buck, Especially if you are looking to go 4.0l is a complete swap out of a 91-95' YJ. You get the HO 4.0l engine and the TF 999 3 speed. The computer swap is easy too. You will need a spacer ring, but if you are looking at clocking the Dana 300 up for clearance then all you have to do is add an extra 1/2" spacer ring which can be purchased at the same time to maintain proper spline engagement.
Everything else will swap right over. You can also get the steering column out of a Waggy to get Tilt and Automatic. The linkage from the YJ will work but might be easier to just order a Lokar Cable set up. They are really not all that much money.
There were also a lot of CJ-7's out there with the automatic's in them. So finding the set up out of them for the swap is pretty easy. Simplest swap is the 999 but that just gives you a 3 speed. If you are looking at an overdrive then you might want to start entertaining the 4.0l swap. You can get the OD from a Cherokee and swap that in, but the computer controls make it just a bit harder than the YJ swap. Not impossible, but a little harder.
Carl
cb rogers im going to swap a 1995 yj, tf999 and 4.0l into my 84 .. can you tell me more about that spacer ring and where to get it
… If you are looking at an overdrive then you might want to start entertaining the 4.0l swap. You can get the OD from a Cherokee and swap that in, but the computer controls make it just a bit harder than the YJ swap. Not impossible, but a little harder.
Carl
Actually, if you use an AW4 from a pre 92 Cherokee, the TCU does not interface with the ECU so it is not really much harder. Visit the www.cjoffroad.com forums and use the search function. These questions (and many others about CJ engine and tranny swaps) have been asked and answered many times.
Later, Ken
