I had a vacuum leak around my carb. I went out and got some new gasket material and made some new gaskets. I put it together and it purred perfectly.
Now, about 25 miles later, it is acting up again. I squirted carb cleaner and it is leaking in about the same place.
I have a 4.0 L head and a clifford 4-barrel manifold with a clifford adapter plate on it, with a Weber carb. Is there a special way to tighten this stuff down or torque it? Am I supposed to use anything on the gasket? I put on a red tack dressing that is designed to hold it in place when assembling. Did I make a mistake in using it?
Please help me out here...I am using this on the 4th to drag a friends boat.
