Tub Mounts - 1984 Scrambler
bdawgg
Member
Member
Greenwood
MO
Fixing to put the tub back on the frame…any suggestions on what mounting/bushing kit I need to get?
Thanks
I have the most complete and accurate kit known to man. 235.00 del. Jim 248 722 9427
I can confirm what cj-jim says above. I recently got a set from him and installed them. They are perfect!
I used the 4wd hardware kit and had to cut the bushings to fit. It worked, but if you don’t know the stock height of the original bushings, it is a pain.
Thank you for your interest. Bushings are equivalent to OEM rubber. Jim 248 722 9427
Are there only 2 of the ‘sleeves’ that go on to the scrambler? When we took the tub off it only had 2 so don’t know if I need more or not…
Also, would like to use new hardware for this so where can I get this? The bolts & washers….can I just go to the hardware store and get or are these ‘special’ ?
Any thoughts on this?
call Jim 248 722 9427 he can answer all your questions and supply you with correct components. thank you
From the factory they all have the sleeves.
I remember most of mine were intact, but I went with a 1" lift so used the hardware in the kit.
Here is a set that shows the parts:
https://www.quadratec.com/products/55008_00.htm
