Turn Signals Issue.
Wayne
Cape Coral
Hello:
Incase anyone has come across this issue before - it will same me a ton of time and I am not a an electrician...
All my lights works - all the bulbs a the correct bulbs all the fuses are the correct size fuses (If the lights work, fair to say the grounds are good)?
I have checked all the grounds that I can find and they look clean and secure.
The Problem.
When turn the left signal on (only the left) all four flashers come on..
When I turn everything off and pull the hazard pin all 4 hazard light will come on.
Would anyone think that the signal arm component is bad?
In the 34 years I have owned the jeep in have only had to replace the signal housing/component once, buyI cannot remember why though I do remember when is removed it, it was cracked.
I appreciate any input - Thank you very much.
Wayne.
Sounds like a grounding issue.
Unplug each left signal fixture and try it. Then plug them in 1 by 1.
