understanding tire size
SCWorm
hillbilly born-n-bred
Fort Mill
sc
Just a question to satisfy my curiosity -
Does anyone know of a standard conversion on tire sizes? Some tire sizes list height/width in straight forward inch measurements - ie 32 x 11.50. Other sizes appear in the old traditional measurements 285/75R.
I've never really understood the difference, and when I have a set of tires that are in the 285/75R terms, I don't really know how tall/wide those tires are.
Anybody?
Here is what it says off tire rack. If you google "tire conversion" you should get a mess of calculators.
http://www.redrock4x4.com/tech/tire_calc.php
Section Width
Following the letter(s) that identify the type of vehicle and/or type of service for which the tire was designed, the three-digit numeric portion identifies the tire's "Section Width" (cross section) in millimeters.
P225/50R16 91S
The 225 indicates this tire is 225 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall when mounted and measured on a specified width wheel. This measurement is also referred to as the tire's section width. Because many people think of measurements in inches, the 225mm can be converted to inches by dividing the section width in millimeters by 25.4 (the number of millimeters per inch).
225mm ¿ 25.4 = 8.86"
Sidewall Aspect Ratio
Typically following the three digits identifying the tire's Section Width in millimeters is a two-digit number that identifies the tire's profile or aspect ratio.
P225/50R16 91S
The 50 indicates that this tire size's sidewall height (from rim to tread) is 50% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 225mm and that its section height is 50% of 225mm. By converting the 225mm to inches (225 ¿ 25.4 = 8.86") and multiplying it by 50% (.50) we confirm that this tire size results in a tire section height of 4.43". If this tire were a P225/70R16 size, our calculation would confirm that the size would result in a section height of 6.20", approximately a 1.8-inch taller sidewall.
Sean
I just go to www.tirerack.com and type in the tire size. Select a tire from the list and hit tire specs- it will give you the height, width, width of wheel the measurements were taken on, revolutions per minute, etc.... It will also give you a list of other sizes of the same tire, so you can see what the other sizes convert to.
Happy Easter.
Kyle
Thanks
Thanks guys, both for the explanation of conversion and the source listings. I knew the one set of measurements were in metrics mil, but didn't understand what parts of tires measurements indicated. This will help me on some future tire shopping.
Jay
Man you just made me feel really old. :( H78-15's are what were normal designators for me..... The metric dims were "new" to me in the 70's.
And actually, the H78's really were an 8.55 size, if my memory serves me correctly.
Funny. My first thought was "What's he mean "old, traditional"? That metric deal is brand new! Then I remembered my age. :o The "H"s, the "L"'s, and only really fancy cars would have radials, no way those things were going on a Jeep! TRACKER P/G FOREVER!! :D
Sorry Guys -
Sorry guys, didn't mean to make you feel old. But hey, join the club. I'm also over 40 yrs old, and when I said "old, traditional" what I really was saying was .......what I'm accustomed to seeing. I had never bought tires in inch measurements like 31" x 11.50 (which I'm currently running) until a couple years ago when I bought new tires for my Scrambler.
