Hi, I have been working every day on this thing. So far I have found more rust, busted more knuckles, shed more blood and tears, and chunked more tools across the road and down toward my pond than I know. But, here is the progress so far:
I have installed the 4" superlift springs
wide track axles
steering gear box
repaired the rear brake line (hard line was rusted and had to reflair with new fitting)
repaired the supply and return fuel hard lines (same sit. RUST) with new steel lines.
installed the glass in the 1/2 top (gasket and glass were in the bed when I bought it)
have the rear rancho shocks in place but have to cut off the factory front shock mounts on the chassis and bolt on the taller ones off my cj7 so I can use my ranchos up front
installed the new seats, console, and dash out of my 7
installed the new 31" tires
and are in the process of taking off all the smog, vacume hoses, and wiring off of the engine so I can accually see the very dirty 258! She went on a maiden trip below the pond dam the other day with a 1 year old girl and a 2 year old boy. The factory shifter linkage on the tf 999 auto hung up in 1st gear and we needed to go backwards. Bad deal. Had to walk and get my Toyota, pull the scrambler backwards and free up the linkage. Get the 8 back home and walk back to my yota. It was fun though.
Take care guys and I will post more as it comes!
Shawn
wide track axles
steering gear box
Shawn
