You would need the frame rail and then your door glass would be shorter. The rail has a screw in the top and bolts in the side of the door. You would hope the mounts are in your doors. It would be better if you could find some donor doors.
I have had both types of doors and there is a significant difference in the overall door construction. Both of my door sets were rusted out and I actually was trying to make some doors with the vented window into doors that used fixed vent windows. I would say that anything is possible, but lots of cutting and welding would be involved.
