Vented door window pivot rod part
bbbarc
Charlotte
NC
Anyone know if this part is available? The threaded pivot rod at the base of the vent window as shown in pick, holds spring in place with nut as well
Unfortunately, that part is part of the swinging assembly and I have not seen it sold seperately. From OEM it was only sold as a complete assembly at the dealer as well. :(
I will have that for you from the 10s I just picked up. Two doors are damaged. Pm me if you are interested
I used to braze these back to the frame using a gas torch when they snapped off. They tended to bind up and eventually when worked back and forth they snapped. You need to remove the frame, the remove the glass from the frame, remove the threaded rod, and clean it up before reattaching. Align the rod, fire up the torch. Repaint, reinstall the glass using a rubber mallet and cork/rubber tape. Reassemble the vent to the frame.
