warn winch mount ideas.
scrambler1
waterbury
vt
Hey,
I was hoping for some ideas on winch mounting. I just picked up a warn 9000 xdi off a guy for a good deal.
What I am hoping to do is make a reciever hitch style mount so I can mount it on my Trailer, either one of my jeep's or my truck. This way one winch can do it all. Was hoping that somone else has fabricated a similar mounting system on there trailer to so I could get some ideas.
How is the best way to wire this?
You guys are always helpful,and I appreciate your time,thanks
I have thought about a similar setup for my scrambler which has front and rear hitch receiver tubes (my JD gator is set up with front and rear transferable winch as well, but only a 3000lb). What stopped me is the amount of torque I would be sending through a 2" piece off steel tubing. When towing a trailer, you are really only putting a lot of weight through the receiver on a straight line, turning sharply is usually a low speed (low torque) affair. Unless you are winching in a line that is exactly straight with your receiver tube (with a 9000lb winch) something will bend. On the trail it seems a rare opportunity to be able to winch in a line that is perfectly straight with the vehicle's receiver tube. If you welded two more tubes to the frame of your hitch (creating a three point system) to assist in bearing the torque created by winching on an angle you might be able to create a safe rig. It is one of those things that seems great in the idea stage, but would be tough to execute safely. Jp magazine had a great tech article about wiring a winch, maybe 11/08's issue? Just my thoughts, hope they were welcomed :)
Warn does, or did anyway, sell a nice plug arrangement for just that sort of application. I am sure that you can either get them or something akin to them still. Any good electrical supply outfit should be able to hook you up. AS i recall the ones Warn sold were about the size of a pak of smokes and all you had to do was put the winch in place and plug it in, very cool set up. A buddy uses them to plug the jeep into his truck camper when he gets back to camp at the end of the day. He runs dual batteries in thejeep so he charges them up all day on the trail and then uses the spare jeep battery to run some of the load in the camper.
I'm with Charlie on this one. A transferable winch sounds like a great idea on paper, but execusion is another matter. We had the Warn system on a gov truck a few duty stations ago. We used it to move smaller objects (not the vehicle). The Class III/IV mounting system really limits the capacity of your winch in an offline pull. I'm surprised Warn sells it as a recovery system.
Or you could hard mount it to your cj and if you needed to pull something on your trailer then just hook the trailer to your hitch on front of the scrambler.:D
