Water coming in everywhere
jpdeuce
Houston
TX
This has been a constant issue in my Jeep since I got it. There is some issue with the passenger side upper corner in the way everything fits. Some issue with half-hardtop and the new Bestop soft top. I finally drove it in the rain recently and was able to capture some real time photos. I'm not sure what/if there's something I can do to fix these issues. I assume the windshield glass trim is an easy fix, maybe even some silicone on the outside would fix this one. But that corner seems like it will be a booger to get things straightened up.
This one is middle of the windshield. I guess I know how my cheap Craigslist radio got fried. To my surprise, didn't see any leaks from the seem between the windshield frame and the body, but this was a huge surprise with rain coming through the windshield trim.
Welcome to the world of CJs
You can try trying to run some sealer like aquarium sealer around the windshield/gasket or get a new one. Could be opening up a can of worms though because you don't know what the frame will look like.
There is some adjustment to the doors, loosen the hinge bolts and adjust the door....could be you could also change the door weatherstripping.
Does your gasket between the windshield and frame leak? Most do eventually, that could be an easy fix IF your hinges aren't rusted/frozen.
The windshield folds just fine and that gasket between the windshield frame and the body does not seem to be the issue. It's actually the gasket around the glass.
A google search will lead you to about 15 different sites known for leakage - including the windshield trim seal, the gasket between the windshield and cowl, the cowl vent seal, and plenty more I can't recall off the top of my head. Personally I avoid the rain like the plague, and that has worked without fail. I realize that's not an option for a lot of people though :/
I would avoid using silicone, I believe it may expedite the conversion of steel to rust.
Yea, wish that were an option, but mine is stored outside. With a one car garage and kids, and with the size of this thing, it ain't going in the garage. Maybe one day. :shrug:
The only part I was thinking for a little silicone was the windshield glass trim, where it's leaking in the middle. I figured a little on the top edge of the outside would keep it from coming in there. Maybe not. The door corner is a much bigger issue that no amount of silicone would fix, short of covering the Jeep in it.
Get a nice tarp and put it over the top. Cheap and affective
Sent from my SM-N910P
You know, I'm not opposed to covering it at all. If someone could recommend a good car cover that could protect it from water, but also let it dry out when it's not raining (so everything doesn't just rot under there) I would be all for it.
I use a Pep Boys cover. It has worked great for 2 years so far. No leaks and dries quick.
Karl
The brand of the cover I bought is Premium Tech, says "our finest cover." The size is SUV-C.
Karl
Thanks for the recommendations fellas, looks like I will have to get one. Prolly better than my monkeying around with the alignment of all these pieces that connect in the corner. I do need to fix the windshield issue though, as i dont want to start fixing stuff in the dash if I'm gonna freak out when I get caught in the rain. Shouldn't be as difficult of a fix I would think, maybe even just a new windshield glass seal.
I switched to a YJ windshield and no more leaks. The windshield is glued in like a modern car. Not the cheapest solution, but hasn't leaked in years.
