webber carb help
mikey
Paris
TN
My webber is loading up...too much fuel,or not enough air.does anyone know where the air and fuel mix screws are on this carb?i have locked the choke open so it is non existing unless its trying to give it more gas and i dont know it.Or any tips would be greatly appreciated.
Hey Mike
What style of Webber is on the jeep? 32/36 eletric choke or mech? Do you have a fuel pressure regulator tied into the fuel supply line? Pick up a webber manual at any local parts store,they are a big help when you start learning about the webber. Bought one for a baja bug I had years ago. Not to bad to deal with once you get famaliar with them. Shoot me a PM with contact info and I will walk you through a few things if you still need some help.
Later
Sean
mine has electric choke,that is unhooked for now because it kept trying to close off air even when warm.
So after reading some posts i put a fuel regulater on it and hooked up the return lines,i set regulater on 3 pds.and give her a little test run yesterday,so far so good but it 60 degrees out yesterday.
Which model do you have? The DGV & DFV series is very ez to adjust and tune, whereas the new DGEC is and has been trouble from the start.
Well i really dont know it was on the 8 when i bought it.Is there a way i can tell?The regulater seems to have helped alot but it still seems to load a little when idleing for a while.
Yup, look at the opposite to choke end of carb for rather small stamping at the base flange. Or the DGEC will have only one choke plate, at the primary venturi. Hope you will find choke plates on both venturis as that will rule out the problematic DGEC. The old and reliable DGV series are very tuneable. Take a close look at the stamps and let us know what you find.
oh man:( i only have one choke plate.Oh well looks like i will be putting the 360 in hopefully before long.
Sorry, but the engine swap will be less aggravation and cost than tuning that carb, it's a Solex contracted to Weber.
Here is a PDF link to Weber troubleshooting guide, but your DGEC likley won't benefit from the adjustments as it isn't really Weber hence no support is or has been available on the Net, or for that matter even in the box it came in.
Anyway here is the link for what it is worth http://webernorthamerica.com/pdffiles/webertroubleshootingguide.pdf
Best of luck.
Hey Mike
I'm going FI soon ,want to buy my old DGV carb until you swap in the 360?
Shoot me a PM or give me a call.
Later
Sean
And mcmudd thanks so much for your help on this,i am stuck with this one but now i know for future projects.
