What is the difference?
bignickle
Ottawa
ON
Between a hi-lift jack and something called a farm jack, they both look the same, only farm jack is cheaper?
Mike
Mike
Exactly........
Carl
When stored in the elements like the back of the jeep, the hi-lift only requires lubrication a couple of times a year. The farm jack needs to be lubricated every other month. Of course, most folks only lubricate them when they need to use them and they no longer work. I have the farm jack and usually just give the pins a shot of pb blaster every once in a while.
Besides that, just the cost.
I have had my High-Lift for more than 20 years and it still does fine. Got a little rust on it, but WD-40 seems to keep it running.
Be aware that some of those import jacks have hole spacing that is different than the high lift and some of the attachments for them will not work.
Also I think that the high lift is built from better steel.
The big difference is to be sure that you get one with the cast moving parts and not the folded steel. When I worked construction we always used the cast ones. It always seems that the ones with sheet steel parts would eventually fail.
So I voted buy American.
Carl
As always a wealth of experience and knowledge
Thanks again guys...
(spring is almost here...)
Mike
Either one can kick your butt when lowering a vehicle and not keeping control of the handle....
