Wheel Spacer Questions
Breal
Jackson
WY
I Just recently switched out my wheels from 15x10" to 15x7" OEM chrome wheels. I didn't really think about what it would look like going from a 10" to 7" width wheel. I have narrow track axles and it looks kinda funny how inset the tires/wheels look with the 7" wide wheels. My questions are, will spacers help push those back out to the stance it used to have? Are there any downsides to using spacers? What width spacer should I get to match the stance of my old 10" wide wheels? I believe the backspacing on the 15x10's was 4inches. Dont know how to tell but I read that somewhere. Not sure what the back spacing is on the OEM rims. Anything I should look for when comparing brands/models? Anything else I should know or consider? I'm new spacers so any explanation is appreciated.
I should also add that 99% of my less than 2,000 miles a year will be on city roads commuting to work.
After reading some other forums, it sounds like there is quite a bit of controversy over whether it is safe or not to use wheel spacers. Has anyone on this forum ever had any safety problems with spacers?
If I could someday score a set 15x8" oem wheels, would the backspacing be any different than the 15x7 and help push the wheels/tires out a little further? How much cost or effort would it take to switch to wide track axles and would that help address my issue? I'm open for other ideas too.
Spacing out the wheels with an 1 1/2" spacer will just about get rid of your backspacing. That's not a problem for the rear axle but is harder on the front axle and steering. The proper but more costly way to fix that is with widetrack axles which may be out of the question for you. It would be more of an issue if you were off road way more.
I am running 1.5" spidertrax wheel spacers on my '84 CJ7 with Cooper Discoverer STT's 37X12.50R17LT, with Black Rock Type 8 Series 997 rims, 17"x9" with 4.5" of back spacing. If the rims were offered with less back spacing I would have done so but 4.5" was the least amount I could go and I still wanted a little more width. These have been installed for the last year and I have not had any issues at all with them. Most of that time the Jeep has been in Houston and if the horrible roads here won't cause any problems I don't think anything will!
You will get the same amount of leverage and stress on the front axle and bearings from spacers as you will with wheels with less back spacing so that isn't an issue.
Most people run into a problem because they use cheap spacers and/or don't know how to operate a torque wrench. Cheap spacers can have many problems but often don't allow enough of the studs to make adequate contact with the lugs which is a major problem. Just get a quality set of spacers (SPIDERTRAX), make sure the mounting surfaces are clean and free of dirt/debris, use lock light where directed, and torque correctly; do this and you shouldn't have a problem.
Most of our club members have wheel spacers. 1.5" or 2".
This TJ is running 1.5" front and rear. stock tj axles.
This TJ is also at 1.5" on 42's..
this sammy runs 1.5"
on 42's, 2" spacers...
My point being that some big hosses with big engines still hold up to it as long as you don't neglect them.
None are scramblers yet, however 1.5" spacers are on my list. I too have NTA's and it will certainly help with my stance.
So,
I second the above....read the directions, follow the directions, Check the torque after about 100 miles and again after every wheeling event, or during if it's a weekend trip.
None of the club members have had any failures. They all bought well known brand(s)
You'll be fine with them. Post up pics..
