MomoJeep
- Seattle
- WA
Conventional wisdom says front tires wear faster due to handling both the majority of braking and steering. Is this necessarily true?
(I don't rotate tires as often as I should, and noticed the front were indeed more worn. So I swapped them with the rear, and it's been several thousand miles and the tires that are now on the front (with more tread) do not seem to be catching up with the amount of wear on the tires that are now on the rear.)
Also, there's the assumption that the front of the jeep is heavier (Engine). But I have a hardtop and a lot of gear in the back.. Still heavier in the front?
