So this project kind of got side tracked for a household move, a scrambler redo and various other distractions. I've been working on it off and on for the past two weeks to get it ready to go for when I get the jeep back. The caliper paint turned out to be a bad choice as it flaked off. It said there was primer in it, but something with the aluminum housing didn't let it adhere. I got all of it off and repainted with two coats of etch primer, four coats of acrylic enamel and two coats of clear. I kind of used this to get my rattle can techniques from terrible to not terrible. It came out passing fair.
I replaced all the old solenoids with a super winch contactor (which is an american albright, pretty much) Rewired it and replaced the plug with a 4 pin round trailer plug. I made my own winch controller out of a stock AR15 handle, a length of electrical cord and the male end of the 4 pin round trailer plug. Sounds ghetto as all getup, but it actually came out really well.
I repainted the cover with krylon fusion for plastics, taped off the the big W and painted it was red automotive enamel.
The sticking point for me has been the gear that I had to replace. When I went to put the brake shaft back together, there wasn't enough room left for the retaining clip on the end. I took it apart and put it back together about 5 times to figure it out and finally realized that the thickness of the new part and the old were about 10 thousandths off. I debated finding a machinist in my area and have him turn it down. That was another hold up of a couple weeks. Finally, I decided to do it on the grinder with a micrometer, lots of time and more patience than I usually am able to muster. After test fitting about 20 times and taking off 1 thousandths at a time, I got it fit with a little play for the spring inside the brake mechanism. I rotated it throughout and kept the pressure light to keep it evenly ground throughout and it came out perfect.
I got it all put back together and sealed up and here's how she sits now.
I need a mount, some cable, and to run the #4 welding wire to the battery and she'll be ready to go. Hanson Offroad makes a pretty universal mount that I'll probably end up going with.
Oh, I also need to hit up Joe West on here for an SE decal to finish off the top.
BTW, I ran the manufacture code and it turns out this winch was made August of 1983 so it's the same year as my Jeep!
