Will '03 Sahara tires and rims fit '83 CJ-8?
Scramblin_Jim
Goodyear
AZ
A fellow Jeeper is getting rid of his stock tires and rims from his '03 Sahara. The tires are 30x9.50Rx15 and mounted on the stock rims.
Can I run them on my stock CJ-8?
I would like to replace the street tires that are on some old ugly steel rims for these aluminum rims and newer offroad tires if they will work; just until I can buy what I really want. That way I would feel better about going off road. What ya think?:confused:
Nope! Wrong bolt pattern.
CJ.......5 on 5 1/2...... TJ 5 on 4 1/2. The tires will work on your rims, though.
Is he giving you a good deal? If so, use the tires and sell the TJ rims and use the money you get for new rims.
Paul
Its a deal
That's what I figured they had different bolt patterns. I also thought about using the tires only as it is a real good deal - free! Just not sure there is a market for used stock rims and really don't want them around if I'm not going to use them.
Thanks for the info.
Jim
If those are the 30x9.50 stock tires then the rims shoudl be the 15x8's.
I have a 01' TJ and mine are the canyon style. There is a decent market for them on eBay and usually locally. Take a look for jeep rims and see what pops up.
Worst off list them for $25 plus shipping. They are bound to sell. Ought to go for ~$100-$200.
Heck even if you only get $25 it was worth it for the tires.
Carl
If they are 15x7 or 15x8 there should be a market, and you should be able to make a few bucks.
You can mount a 12.5 wide tire on either of those rim sizes.
If it's free, I'd grab the tires for sure!
Erik
Will do it!
Thanks guys for the advise. I'm planning on going over Friday and getting them. Will be interesting seeing what develops from my find. he also has some Toyota Tacoma stock rims he want removed as well. Based on what you guys are saying, might as well go for those as well and make a little change for some rims I will want.
