jscherb
- Elmira
- NY
I'm in the process of refinishing a pair of 94 Wrangler doors to replace the originals on my Scrambler. While doing this I want to fix two major design flaws.
First, the joint where the vertical window frame joins the door panel sheet metal. In TJ Wranglers, Jeep wised up and welded this joint, but for CJ's and YJ's, the metal was free to rub if the door flexed and this is a common cause of rust on the door frame. I've welded these joints and have sculpted the weld to make nice fillets.
The second thing I want to fix/prevent are the stress cracks that develop by the vent window frame. One of my Wrangler doors is not cracked, the other has a crack that's short enough that it doesn't show because it is hidden by the weatherstriping. I've welded the one crack, but I know that's not enough to prevent it from happening again some years from now.
Has anyone repaired their doors and reinforced this area? What have you done? Ideas please...
