- Rockville
- VA
I'm trying to level out my Scrambler, the front sits a bit lower than I want. I have a set of older RE 4.5 XD springs. The rear is good/high enough. I called RE, they're telling me to use a set of rear springs on the front (their 1451 springs). When I measure my spring hangers, the front is 43.25" hanger to hanger and the rear is 44". So the front should take a shorter spring, if the weight on them is equal to be level. My current springs, with the full weight of the Jeep on them are 45 1/8" eye to eye on the fronts and 44 1/8" for the rear. So, the fronts are sitting much flatter than the rear.
Tomorrow, I'm weighing the Jeep at all 4 corners to see just what my front to rear weight bias is. If I put the same spring front and rear, the front will be forced into more arch, giving more lift, unless there's significantly more weight in the front.
Comments, suggestions? Anyone else play with this issue? I do have a 360 with a winch and, sort of, heavy bumper on the front.
