Jeff,
Whos variable-speed controller did you go with?
Thanks, Duane
I used the FK-35 from Delta Current Control (
http://www.dccontrol.com/0820.htm), and it's an exceptional piece of technology, but it is a very small company and the owner is somewhat customer-service-challenged, so even though I'm completely happy with the DCC product, I'm not sure I'd recommend doing business with them.
In fact, I bought a Flex-A-Lite variable speed controller (
http://www.flex-a-lite.com/auto/html/vsc.html) to have as a spare in the event my Delta unit ever failed - the FAL unit came out after I installed the DCC unit but it has the same capabilities and features as the DCC unit and would be a pretty much direct swap into the wiring I installed for the DCC unit.
So if I were to do it again I'd probably install the FAL unit instead of the DCC unit, not because of technology, but because of DCC's customer service.
The DCC web site is worth exploring in any event, because you'll find interesting fan spec info, technical theory info on variable speed fan controllers, and some wiring and circuit ideas which should also work with the FAL unit. For example, the photo shows the control panel I made for my fan - the switch allows you to turn the fan off completely (and the red LED will light as a warning that the fan is stopped), turn it full on manually, or leave it in automatic mode, and the green LED actually changes color from green (fan not running) to yellow (fan running slowly) to red (fan full on) so you always know what the fan is doing. This circuit should also work with the FAL unit as well.
Let me know if you need any further info...
Jeff
