Being both a Commando and Scrambler owner, I think I can answer a few of these questions. The C101 Jeepster Commando had 101" wheelbase, came with a 225 v6, and ross manual or later saginaw power steering. Axles were closed knuckle D27 front, and a D30 or a 10 spline 2 piece D44. In 72 AMC took over, and stretched the wheelbase to 104", all in front of the firewall. This was to accomodate the straight 6 or the 304 v8. Axles became a flanged D44 rear and an open knuckle D30 front, but still drum brakes, 11" though. Steering was saginaw power or manual. This rig, produced for only 2 years, was pretty close to the Scrambler. It did have a distinctive (ugly?) front end though, looking like a Scout mated with a Bronco. If you're looking for a builder, the 72-73 models are the way to go for mechanicals. A CJ style front clip is pretty much a bolt on for them.
Advantages of the Commando are longer springs, for increased flex and a smoother ride. The frame is beefier, and instead of getting wider through the center it stays the same width all the way back. A complete Scrambler tub and front clip could be made to fit on a 72-73 Commando frame, with minor mods to the rear body mounts. Using it as a base for a "Bob Job" would be a little difficult, though, as the longer Commando springs mount to the rear crossmember. I can supply pics of the Commando frame I'm building if any one is curious.
A Commando windshield frame is shorter than a Scrambler, and there is less headroom. The floor, however , is level with the door opening, easy to hose out! Commandos are pretty unique rigs, and there is quite a following, like Scramblers. If you think finding Scrambler parts is hard, look for Commando parts-there aren't many. Most everything is custom built.
I was actually looking for a Scrambler when I found my Commando. Now that I have one of each, I love and appreciate the uniqueness of both of them. My Commando is going to be my hardcore rock rig, and my Scrambler is my daily driver.
If anyone has any questions on Commandos/Jeepsters, feel free to ask me. I'll be happy to respond.
