- Cave Creek
- AZ
OK, so I spent the past week and a half rebuilding my front axle peripherals so I thought I'd write up a thread about it in case anyone needs it in the future. I'll first say that my steering wasn't bad to start out - a little loose, but the ball joints were loose and I had what I think was some signs of loose bearings as well. Now that it's done...you guessed it, my steering is worse! I think/hope it's a matter of the weakest link showing up, likely the steering shaft (which I have on order), but maybe the gear box. I've tentatively ruled out the gear box by hand turning the lower steering shaft and watching the pitman arm and box itself for movement - pitman moves and box is solid.
Here's the parts:
Also a few other things like Hi-temp axle grease, gear puller rental, prevailing torque nuts (found at a specialty hardware store), rattle can paint, snap ring pliers, and beer for my go-to mechanic in Fort Collins, David Napier
who helped me with the ball joint, U joint, and spindle bearing removal/installation. Final grand total: somewhere around $500 for both sides.
Here's the parts:
- Spindle nut socket (Oconee: Omix 16711.01): $12.39
- Spindle nut/washer kit (Oconee: Omix 16710.01 x2): $12
- Timken bearings, race, and seal (Foothills Off-road Products: D307683WBK x2) $70+ shipping
- Rotors (Autozone: 5110 x2) $68
- Brake dust shield pair (Oconee: Omix #11212.02) $70.00
- Spindle bearing, seals, and retainer (Autozone: SBK-1 x2) $26.00
***note, the kit did not come with the plastic retainer pictured, mine was luckily in good shape so I reused it***
- Upper and Lower ball stud kit (AutopartsExpress.com: Moog K8194/95t x2) $100.20+10 shipping
- U Joints (Drivetrain America: Spicer 5-260x) $48 + 10shipping
- Upper and Lower Ball joint sockets and 3/4"adapter (Ace) $35
