Front axle partial rebuild
walkerhoundvm
Just trying to stay upright
Cave Creek
AZ
OK, so I spent the past week and a half rebuilding my front axle peripherals so I thought I'd write up a thread about it in case anyone needs it in the future. I'll first say that my steering wasn't bad to start out - a little loose, but the ball joints were loose and I had what I think was some signs of loose bearings as well. Now that it's done...you guessed it, my steering is worse! I think/hope it's a matter of the weakest link showing up, likely the steering shaft (which I have on order), but maybe the gear box. I've tentatively ruled out the gear box by hand turning the lower steering shaft and watching the pitman arm and box itself for movement - pitman moves and box is solid.
Here's the parts:
  • Spindle nut socket (Oconee: Omix 16711.01):
    $12.39​
  • Spindle nut/washer kit (Oconee: Omix 16710.01 x2):
    $12​
  • Timken bearings, race, and seal (Foothills Off-road Products: D307683WBK x2)
    $70+ shipping​
  • Rotors (Autozone: 5110 x2)
    $68​
  • Brake dust shield pair (Oconee: Omix #11212.02)
    $70.00​
  • Spindle bearing, seals, and retainer (Autozone: SBK-1 x2)
    $26.00​
    ***note, the kit did not come with the plastic retainer pictured, mine was luckily in good shape so I reused it***
  • Upper and Lower ball stud kit (AutopartsExpress.com: Moog K8194/95t x2)
    $100.20+10 shipping​
  • U Joints (Drivetrain America: Spicer 5-260x)
    $48 + 10shipping​
  • Upper and Lower Ball joint sockets and 3/4"adapter (Ace)
    $35​
Also a few other things like Hi-temp axle grease, gear puller rental, prevailing torque nuts (found at a specialty hardware store), rattle can paint, snap ring pliers, and beer for my go-to mechanic in Fort Collins, David Napier ;) who helped me with the ball joint, U joint, and spindle bearing removal/installation. Final grand total: somewhere around $500 for both sides.
Front axle rebuild document
Here's the doc I made up to work by, including all these parts and step-by-step instructions. It's broken down into the typical areas you could do on their own, from "just the hubs," to "all the way to the spindle," to "all the way down to the ball joints."
And the nitty-gritty for the whole process:
Hubs
1. Remove wheel
2. Remove lockouts, set aside for cleaning
3. Remove calipers and hang them from the frame. Make sure they're stable and not placing any strain on the hoses there!!
4. Remove outside lock ring (need snap ring pliers w/ multiple tip types)..Don't forget to put this back on when you're done!!
5. Remove spindle nuts after aligning rear locking washer (need spindle nut socket)
6. Yank hub and rotor off.
7. You'll need to hammer out the lug bolts to release the hub from the rotor.
8. Pry rear grease seal off from the hub and remove bearing, outer bearing comes out easily (this took some hammering to get the seal off)
9. Clean hub thoroughly and remove races by tap-walking it out (use a brass punch to minimize damage to the hub internals)
10. Install new race with seal and bearing driver tool (a round, flat-faced aluminum driver you can rent from auto parts stores). ***Note: races and bearings may look identical to each other, but they're not. Make sure you install the correct race for the correct bearing (inner vs. outer), and in the right direction. Races are central to the hub, and bearings come from either end with concave end facing in, like this: inner side of hub [ >) (< ] outer side of hub, where ">,<" are the bearings and "),(" are the races. See also the diagram in the next post.
Hub Reinstall
11. Reinstall rotor
12. Replace inner spindle nut with seal backer, torque to 50ft/lbs and then back off 1/8-14 turn, enough so that there is no play but no drag when the rotor is spun
13. Replace outer spindle nut with washer backer, torque to 65ft/lbs
14. Pack bearings with hi-temp axle grease
15. Fill hub, races, and grease seal with grease
17. Replace caliper *anti-seize* at mating faces
18. Replace lock-ring
19. Replace lock-out
20. Replace wheel (paint first if you want) and torque to 80ft/lbs &#8211; rechecking daily for several days , and put *anti-seize* on the lug bolts
Spindle bearings
1. Remove &#8220;prevailing torque&#8221; nuts holding brake dust shield and spindle; sand, prep and paint dust shield. Mine were trashed, so I ordered some from Oconee made by Omix. The driver's side fit, the passenger side was machined wrong so had to be pressed around the caliper hanger.
2. Remove spindle using rented gear puller. These things make men out of mice, can't say enough about them. You may need a day or two worth of PB blaster to ease it along, though.
(borrowed from civilianjeep.info)
3. Remove nuts holding caliper anchor plate &#8211; sand, clean, and repaint
4. Pull the axle through the knuckle opening, being careful to try to keep it level on the way out.
5. Check axle splines for wear or damage
6. Replace U-joints (with help from your mechanic, if necessary). Had a little trouble with mine, they needed a little hammering to get the new ones in place.
7. Replace spindle bearing and seals. Apply grease to every mating surface of the bearing and the seals, as well as the interior of the spindle. My spindle bearing was frozen inside the spindle, and we had to MacGuyver a pull to get it out - a three pronged collapsible puller with a slide hammer attached. These things did not want to come out with an angled driver.
8. Using an emery cloth, clean the surface of the snub axle that the spindle bearing mates with
(again borrowed from CJ.info)
Spindle Reinstallation
9. Replace caliper anchor plate
10. Replace axle shaft, again trying to keep it level so that it doesn't catch any of the rusty interior of the axle on the way in.
11.Reinstall spindle after applying never seize to the snub axle mating surface
12. Replace dust shield
13. Replace &#8220;prevailing torque&#8221; nuts with new nuts, tighten to 25-30ft/lbs *anti-seize*
Ball joints
1. Loosen both castle nuts and pop the bottom ball joint with a joint fork. Leave the upper castle nut flush with the top of the centering bolt, then hammer away until the kunckle drops loose.
2. Remove steering knuckle by completely unscrewing both castle nuts; after removing tie rods, it should come out easily.
3. Remove the split ring that centered the upper ball joint &#8211; may need a socket, may come out with fingers. Mine came out easily with my fingers +/- driving it with a screw-driver.
4. Remove the ball joints with a rented remover/installer tool (with help from a mechanic with the proper tools if you know a good one)
5. Sand, prep and paint steering knuckle and caliper retainer
6. Install new ball joints with installer tool. ***if you go with ball joints with zerk inserts, for the love of God make sure the inserts are pointed in a direction you can reach them with a grease gun! Otherwise you may have to add an angled insert like I think I'll have to do for one of mine.***
7. Reinstall steering knuckle; lower ball joint nut torque: 80ft/lbs, split ring: 50ft/lbs (in the protocol, but the OEM ones and the Moog ones didn't bottom out, so I left them flush with the top of the knuckle - see below, though, this was a bad idea and I needed a tool to do it right to fix a death wobble), upper ball joint: 100ft/lbs *anti-seize* on all threads here. Although the lower Moog joint came with a lock ring, the ball joints were pressed in and the installation ring didn't expose itself, so installing it wasn't possible.
That's it, you're done! The passenger side I pulled over a couple of days, the driver's side I pulled in about an hour. Reinstallation after the ball joints and U-joints were replaced took me about 4-5 hours. Total labor somewhere in the neighborhood of 10-15 hours, including paint time.
Last thing I'll add is that I had next to no mechanical experience prior to buying this CJ two years ago. This was probably the biggest job I've done to date, and it really wasn't too bad with a lot of patience, the right tools, and some great help.
Some other pics I borrowed from Civilianjeep.info that show the parts involved:
Rotor and Hubs:
Spindle and steering knuckles:
Figured out the source of my wobble - Step #7 of the ball joint installation in post #4. "Torque split ring to 50ft/lbs" etc. I didn't think much of it, but as CB pointed out in another thread on death wobble, turns out that pre-load is pretty important. I purchased a Moog ball joint socket, redid the whole thing with knuckle torquing as follows:
1. Torqued bottom joint to 80ft/lbs
2. Torqued the split ring to 50ft.lbs with this tool from Northern Auto Parts (clicky for tool T40207, $26 after shipping):
3. Torqued the top castle nut to 100ft/lbs
Reassembly as above.
While I was down I installed a Borgeson steering shaft with dampener from buyautoparts.com, (clicky for part #88-00027, $250 after shipping):
Painted it black after dry fitting based on recommendations from other CJ owners.
Drives like a dream now, better than before and I have full confidence in the front end. Looking forward to some trail runs now!
AWESOME information!!!
Thanks for the write up. :thumbsup:
Nice write up and pics! :thumbsup: Is this a stock dana 30 front axle? Thanks for your effort to post all this. It's a really good step by step guide. :cheers:
I can't tell you how many times I have told people that have replaced ball joints that it is probably the cause of their issues, only to be told I didn't know what I was talking about... so I leave it alone... and then lo and behold, a few weeks later, they discover that it is the ball joints!!!!
It scared the heck out of me the first time I did it... I limped home 50 miles at 20 mph cause that is how fast I could go. It was a well researched item and then I wrote all about it over and over cause I never wanted anyone else to go through it. It is scary stuff, and washing your shorts as a grown man is never fun ;)
Don't forget to check the amount of rotational torque it takes to turn the knuckles after assembling and torquing the ball joints:thumbsup:
Yep, everything stock for an '81. I haven't measured the caster angle, but I assume it has been corrected after the 4" spring lift done by the PO...no wobble before the work and none after now that it's been corrected. What I most wanted to do here is have a collection of all the parts and where they were sourced. There are a few Dana 30 write-ups out there, but I spent more than a few hours just trying to find everything I'd need so I could plan ahead.
Your comment in that other thread is what solidified it for me. I was suspicious before but that convinced me to dive in there again and fix it. I noticed it being tight but driving home the first afternoon I just about crashed accelerating up to 55 going down a hill. I know about washing your shorts. My mechanic friend thought it could be the box, and he and I went down the "is it my steering box, is it my steering wheel, is it my alignment" and I ruled all of them out. I haven't told him I figured it out yet. My steering shaft I only replaced because there was some play and it was rusted pretty good. The box looks great and I hope I never have to go in there and get it out!
:cheers:
I've been through a few threads and I can't see the difference between a '81 and '82-'86. I have a Dana 30 front end with a busted front axel (input and output) on the passenger's side. I'd like to buy a stock replacement, but most of the sites where I get parts say the replacement is for '82-'86. Why? It's all a Dana 30 front end right? Did the number of splines change at some time? I don't want to upgrade to anything out of the ordinary; stock is good for me. I just don't want to order the wrong thing.
81 is narrow track and the 82-86 is the wide track so the axle inner lengths will be different.
I should delete that post so know one knows how amateur I am...
